17268 Discussions
Quartus ii18.0 standard and modeslsim20.1 error
JunDai
Nativelink 错误 内部错误:无法运行 ip-make-simscript: 2025.06.02.17:39:02 Info:Doing:ip-make-simscript --nativelink-mode--output-directory=dds_iputf_input --spd=D:/quartus18.0-projects/dds/quartus_prj/sine/sine.spd</b 线程'main'java.lang.Error:调用 quartus_sh 意外失败:package'tb2”在执行 oad“tb2·时未静态加载 com.altera.sopcmodel.sbtools.simscriptgen.SimulationLibraryInfo rmation.runTclScript(SimulationLibrarylnformation.java:234) 在 com.altera.sopcmodel.sbtools.simscriptgen.SimulationLibrarylnfo rmation.generateSpdFiles(SimulationLibraryInformation.java:147) 在 com.altera.sopcmodel.sbtools.simscriptgen.SimulationLibrarylnfo rmation.initialize(SimulationLibraryInformation.java:194) 在 com.altera.sopcmodel.sbtools.simscriptgen.SimulationLibraryInfo rmation.(SimulationLibrarylnformation.java:115) 在 com.altera.sopcmodel.sbtools.simscriptgen.SimScriptGen.act(Sim ScriptGen.java:211) 在 com.altera.utilities.AltCmdLineToolBase.runTheTool(AltCmdLineTo olBase.java:718) 在 com.altera.sopcmodel.sbtools.simscriptgen.SimScriptGen.main(Si mScriptGen.java:178) 上。检查 NativeLink 日志文件 D:/quartus18.0-projects/dds/quartus_prj/simulation/modelsim/d ds_nativelink_simulation.rpt 以获取详细的错误消息
RichardTanSY_Altera
Could you try to install the latest Quartus version 24.1std & Questa, and see if the issue persist?
Do you have the project to share so I could try to duplicate the issue from my side?
FYI, Modelsim FPGA Edition has been replaced by Questa FPGA Edition.
Richard Tan
JunDai
RichardTanSY_Altera
Any update on this?
Richard Tan
RichardTanSY_Altera
I have no issue running nativelink simulation flow using Quartus 24.1std and Questa Intel FPGA edition.
Could you try to upgrade the tool and see if the issue still occur?
Richard Tan
RichardTanSY_Altera
Any update on this?
Do you able to resolve the issue using the Questa Intel FPGA Edition?
Richard Tan
RichardTanSY_Altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for reaching out to us!
Richard Tan
