17259 Discussions
Quartus prime problem report - active serial SST26VF032B
LOPEZ_olivier
I have this message when in want to programming my board:
Problem Details
Error:
Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_engine.cpp, Line: 4555
count >= static_cast<DWORD>(device_chain->size())
Stack Trace:
    0x55ee1: PGME_PROGRAMMER::get_device_chain_with_dummy_jtag_bit + 0x161 (pgm_pgme)
    0x3fe8f: PGME_PROGRAMMER::engage + 0x288f (pgm_pgme)
    0x8b715: PGMWQ_PROGRAMMING_THREAD::run + 0x25 (pgm_pgmwq)
    0x2c760: QThread::start + 0x3e0 (Qt5Core)
    0x1257c: BaseThreadInitThunk + 0x1c (KERNEL32)
    0x5af27: RtlUserThreadStart + 0x27 (ntdll)
End-trace
Quartus Prime Version 22.1std.1 Build 917 02/14/2023 SC Lite Edition
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 22.1std.1
Build: 917
Edition: Lite Edition
I'm not sure if i made the good manipulation.
I tried to flash the memory connectited to my 10CL040YF.
The memory is the SST26VF032B.
But this memory are not in the list sor i'm not sur if i've choos the good ...
Some help please .
Farabi
Please refer to supported flash devices here : https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-guidance/configuration-support.html
The flash you are using is not supported.
regards,
Farabi
FvM
the linked device support list is hardly an exclusive specification, just tells which devices are known to work.
It's not clear which configuration device settings are you using in Programming File Converter tool. Do you use the "new device" feature to define correct programming commands for SST26VF032B?
Frank
LOPEZ_olivier
My request was made 3 months ago.
Since then I have succeeded in creating a new device to make a .jic which I load into my FPGA.
FvM
Very good, that's what I expected.
"flash isn't supported" should be rephrased "there's no predefined support, need to edit configuration"
