I followed the instructions on the altera website to set the usb port settings in linux in the rules.d directory in order to run the usb blaster. That did not work and the access rights are not set. On Ubuntu 12.04 LTS, the setting in the rules file 51-usbblaster.rules has to be # Altera USB-Blaster for Quartus FPGA Software SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666" SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666" SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666"# USB-Blaster II SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666" SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666" I used that with a Altera DE1 board with on-board blaster and that worked. Regards Friedrich链接已复制
3 回复数
I have same OS and Quartus, and have tried all possible approaches posted. I still can not find the build-in USB-blaster II from my DE5-NET board. if lsusb, i can get: Bus 001 Device 013: ID 09fb:6810 Altera But jtagconfig, it prompts: No JTAG hardware available Have you met the same problem? Regards, Di--- Quote Start --- Hi, if lsusb, i can get: Bus 001 Device 013: ID 09fb:6810 Altera But jtagconfig, it prompts: No JTAG hardware available --- Quote End --- Hi, maybe you can have a look here and check the file permissions? http://www.hs-augsburg.de/~beckmanf/dokuwiki/doku.php?id=ubuntu_virtual_cae_system Regards Friedrich
Hi Friedrich,
Thank you for your reply. I checked the permission of my usb port. crw-rw-rw- 1 root root 189, 133 Dec 9 09:37 006 I think it's fine. But the device is still not available. Regards, Di
