17261 Discussions
Question About Graphic editor
I am new with the graphic editor. How do I label the nets for error signals instead of directly connect them? Thanks.
is it erroring out in Analysis and Synthesis? can you post the error.
i'm not sure if the required AHDL syntax can do [0:3], try [3:0]. other than that it looks like it should work
I tried using [0..3]. It works now. So we can not use [0:3] format, right?
seems that way, you could try searching for AHDL documentation if this is legal or not. glad its working :)
Another question is that I have a input signal goes to 5 places. Do I need to use a buffer when I edit the gdf? Does the software will automatically assign a buffer for it after synthesize? Thanks.
no, you can just have an input pin and connect it to all of the destinations using a point to point net or using the named nets like you have in your example
Thanks for your answer.
I am migrating an old design(Quick Work) using Max Plus II. Do you know how to realize the attached schematic use Max Plus II. Thanks for your help.
