Hi
I working on image processing in cyclone II. I have RGB data, each channel having 8bit sample value. image size is 640x480, 30Hz. The data is following in the following manner: R G B, R G B, R G B... I want to draw a small rectangle or cross on the display. please suggest me, how it is possible? Your suggestion will be appreciated. Thank You.Link Copied
