16652 Discussions
ROM and RAM connection
Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM
This is code for ROM
LIBRARY ieee; USE ieee.std_logic_1164.all; use STD.textio.all; ENTITY sync_rom IS PORT ( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255 ); END sync_rom; ARCHITECTURE rtl OF sync_rom IS BEGIN PROCESS (clock) BEGIN IF rising_edge (clock) THEN CASE address IS WHEN 0 => data_a_i <= 128; data_b_q <= 128; WHEN 16 => data_a_i <= 128; data_b_q <= 128; WHEN 70 => data_a_i <= 128; data_b_q <= 128; WHEN 400 => data_a_i <= 128; data_b_q <= 128; WHEN OTHERS => data_a_i <= 0; data_b_q <= 0; END CASE; END IF; END PROCESS; END rtl;
This is code for RAM
library ieee;use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity dp_ram_rbw_scl is generic ( DATA_WIDTH : integer := 256; ADDR_WIDTH : integer := 256 ); port ( -- common clock clk : in std_logic; -- Port A we_a : in std_logic; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0); data_a : in std_logic_vector(DATA_WIDTH-1 downto 0); q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); -- Port B we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0); data_b : in std_logic_vector(DATA_WIDTH-1 downto 0); q_b : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end dp_ram_rbw_scl; architecture rtl of dp_ram_rbw_scl is -- Shared memory type mem_type is array ((2**ADDR_WIDTH)-1 downto 0) of std_logic_vector(DATA_WIDTH-1 downto 0); shared variable mem : mem_type; begin -- Port A process(clk) begin if(clk'event and clk = '1') then q_a <= mem(conv_integer(addr_a)); if(we_a = '1') then mem(conv_integer(addr_a)) := data_a; end if; end if; end process; -- Port B process(clk) begin if(clk'event and clk = '1') then q_b <= mem(conv_integer(addr_b)); if(we_b = '1') then mem(conv_integer(addr_b)) := data_b; end if; end if; end process; end rtl;
after this this I write TOP level entity
library ieee;use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all ; use ieee.math_real.all ; use ieee.math_complex.all ; entity ROMRAM is port ( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255; DATA_WIDTH : integer := 256; ADDR_WIDTH : integer := 256; clk : in std_logic; we_a : in std_logic; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0); data_a : in std_logic_vector(DATA_WIDTH-1 downto 0); q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0); data_b : in std_logic_vector(DATA_WIDTH-1 downto 0); q_b : out std_logic_vector(DATA_WIDTH-1 downto 0); end ROMRAM; architecture rtl of ROMRAM is --- Component decalarartion Component sync_rom is port( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255 ); end component; Component dp_ram_rbw_scl is generic ( DATA_WIDTH : integer := 256; ADDR_WIDTH : integer := 256 ); port ( clk : in std_logic; we_a : in std_logic; addr_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ; data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_b : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end component; for all : sync_rom use entity work.sync_rom(rtl); --for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl); --Signal data_a_i: integer range 0 to 255; --data_b_q_a: std_logic_vector(255 downto 0);--interanal signals begin --inst : dp_ram_rbw_scl port map ( addr_a=> addr_a, --clk=> clk,we_a=>we_a,data_a=>data_a,addr_b=>addr_b,data_b=>data_b,we_b=>we_b); q_a<= addr_a and data_a; -- Component Instantiation C1: sync_rom Port map ( clock => clock, address =>address, data_a_i =>data_a_i, data_b_q =>data_b_q ); C2: dp_ram_rbw_scl Port map ( clk=>clk, we_a=>we_a, addr_a=>addr_a, data_a =>data_a, q_a=>q_a, we_b=>we_b, addr_b=>addr_b, data_b =>data_b, q_b=>q_b ); data_a_i<=to_integer ( unsigned (data_a)); data_b_q<=to_integer ( unsigned (data_b)); end rtl;
But this code doesnt work/Could you please give me some hints for solution? I want to connect data_a_i(ROM) with data_a(RAM) and data_b_q(ROM) with data_b(RAM)
I get next errors
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value
Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value
you haven't declared signals in top level, you just copied names of your lower level modules.
On the top level I should you use different names of the signals?When I define entity ROMRAM and the lower entity I should remain the same?
--- Quote Start ---
--- Quote End ---
use any name but declare them. The top level does not view signals inside lower modules as declared at top level
Thanks)I got it)pls say how I can convert std_logic vector and integer?I do it like this but not works
C2: dp_ram_rbw_scl Port map ( clk=>CLOC, we_a=>we_ai, addr_a=>addr_ai, data_a =>data_a_i, q_a=>q_ai, we_b=>we_bq, addr_b=>addr_bq, data_b =>data_b_q, q_b=>q_bq ); data_a_i<=to_integer ( unsigned (data_a)); data_b_q<=to_integer ( unsigned (data_b)); end rtl;
data_i <=to_integer(unsigned(data_s));
is ok if data_i is integer ad data_s is std_logic_vector and you have library numeric_std
yes.data_i is integer.
Im using library numeric_std
but I have error
Error (10476): VHDL error at Vhdl2.vhd(67): type of identifier "data_a_i" does not agree with its usage as "std_logic_vector" type
--- Quote Start ---
but I have error
--- Quote End ---
double check your declarations or copy your code snippet here
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all ; use ieee.math_real.all ; use ieee.math_complex.all ; entity ROMRAM is port ( CLOC: IN std_logic; ADD: IN integer range 0 to 511; DATA_WIDTHi : integer := 256; ADDR_WIDTHi : integer := 256; clk : in std_logic; we_ai : in std_logic; addr_ai : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_ai : out std_logic_vector(DATA_WIDTHi-1 downto 0); we_bq : in std_logic; addr_bq : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_bq : out std_logic_vector(DATA_WIDTHi-1 downto 0)); end ROMRAM; architecture rtl of ROMRAM is --- Component decalarartion Component sync_rom is port( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255 ); end component; Component dp_ram_rbw_scl is generic ( DATA_WIDTH : integer := 256; ADDR_WIDTH : integer := 256 ); port( clk : in std_logic; we_a : in std_logic; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_b : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end component; for all : sync_rom use entity work.sync_rom(rtl); for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl); Signal data_a_i: integer range 0 to 255;--interanal signals Signal data_b_q: integer range 0 to 255;--interanal signals begin -- Component Instantiation C1: sync_rom Port map ( clock => CLOC, address =>ADD, data_a_i =>data_a_i, data_b_q =>data_b_q ); C2: dp_ram_rbw_scl Port map ( clk=>CLOC, we_a=>we_ai, addr_a=>addr_ai, data_a =>data_a_i, q_a=>q_ai, we_b=>we_bq, addr_b=>addr_bq, data_b =>data_b_q, q_b=>q_bq ); data_a_i<=to_integer(unsigned(data_a)); data_b_q<=to_integer(unsigned(data_b)); end rtl;
c2 data_a is std_logic_vector and you are connecting it to integer..
ok/what should i do.how to convert it or?
any help)?
--- Quote Start ---
any help)?
--- Quote End ---
use same type for port map then change type afterwards a required. Normally we do std_logic_vector at interface, signed/unsigned or integer internally
Could you please give me example in my code/how should i do
--- Quote Start ---
--- Quote End ---
declare these in top lvel
data_a : std_logic_vector...);
data_a_:i: integer ...;
connect data_a to data_a of c2
assign data_a to data_a_i through conversion:
data_a_i <= to_integer(unsigned(data_a));
connect data_a_i to rom
Thanks for replay,I changed as you said,but code still has some errors
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_signed.all; use ieee.numeric_std.all ; use ieee.math_real.all ; use ieee.math_complex.all ; entity ROMRAM is port ( CLOC: IN std_logic; ADD: IN integer range 0 to 511; DATA_WIDTHi : integer := 256; ADDR_WIDTHi : integer := 256; data_a : in std_logic_vector(ADDR_WIDTHi-1 downto 0); data_b : in std_logic_vector(ADDR_WIDTHi-1 downto 0); data_a_i : integer range 0 to 255; data_b_q : integer range 0 to 255; clk : in std_logic; we_ai : in std_logic; addr_ai : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_ai : out std_logic_vector(DATA_WIDTHi-1 downto 0); we_bq : in std_logic; addr_bq : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_bq : out std_logic_vector(DATA_WIDTHi-1 downto 0)); end ROMRAM; architecture rtl of ROMRAM is --- Component decalarartion Component sync_rom is port( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255 ); end component; Component dp_ram_rbw_scl is generic ( DATA_WIDTH : integer := 256; ADDR_WIDTH : integer := 256 ); port( clk : in std_logic; we_a : in std_logic; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_b : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end component; for all : sync_rom use entity work.sync_rom(rtl); for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl); Signal data_a_i_i: integer range 0 to 255;--interanal signals Signal data_b_q_i: integer range 0 to 255;--interanal signals begin -- Component Instantiation C1: sync_rom Port map ( clock => CLOC, address =>ADD, data_a_i =>data_a_i_i, data_b_q =>data_b_q_i ); C2: dp_ram_rbw_scl Port map ( clk=>CLOC, we_a=>we_ai, addr_a=>addr_ai, data_a =>data_a, q_a=>q_ai, we_b=>we_bq, addr_b=>addr_bq, data_b =>data_b, q_b=>q_bq ); data_a_i_i<= to_integer(unsigned(data_a)); data_b_q_i<= to_integer(unsigned(data_b)); end rtl;
errors
Warning (10036): Verilog HDL or VHDL warning at Vhdl2.vhd(57): object "data_a_i_i" assigned a value but never readWarning (10036): Verilog HDL or VHDL warning at Vhdl2.vhd(58): object "data_b_q_i" assigned a value but never read Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value
you got loads of mistakes. Please try draw diagram of rom, ram, romram with all connections named.
by the way why you haven't used generic for width??
ok.Im draw all diagrams as you said, and added generic in top level ROMRAM,now my code start running up to 29% and stop due to cant fit design in device error,but when Im open rtl viewer,I see very strange diagram,not like in my paper
--- Quote Start ---
--- Quote End ---
don't forget datawidth is bitwidth e.g. 8 (for 0~255). you may have put 256 for width
I put like this,is it correct?
entity ROMRAM is generic( DATA_WIDTHi : integer := 256; ADDR_WIDTHi : integer := 256);
--- Quote Start ---
--- Quote End ---
is your datawidth 256 bits? No you mean 8
