Hi :)
i'm new here and i need some help... i work on project and i need to read from kind of machine some letters... there is an ascii code to all letter. this machine send words that i need to read them. in this words i need to check the letters (Y/N)? for the start of this check i want to check one letter/char for example: ( or Y or / . i know that machine send '1' (idle) always and when i press "reset" on this machine, the machine send words that i need to read with start bit+8 bits (data)+stop bit. I'll be glad if someone would help me to write this code or give me examples of rxd codes :) thanks...Link Copied
Start by drawing your design. The www can help you. Use your favorite search engine and search for UART or rs232.
Probably further details ie block diagram would be helpful to illustrate your target implementation.
--- Quote Start --- Start by drawing your design. The www can help you. Use your favorite search engine and search for UART or rs232. --- Quote End --- --- Quote Start --- Probably further details ie block diagram would be helpful to illustrate your target implementation. --- Quote End --- this is my code (out1 is clock 9600 from component that conected to this component code):
library ieee;
use ieee.std_logic_1164.all;
--here, there is one more "use ieee" that i do not remember (not numeric)
entity rxd is
port( out1: in std_logic; --clock 9600hz
rxd: std_logic;
led: std_logic; --to check if the data "00111111" is recieved
end entity;
architecture arc_rxd of rxd is
signal cnt: integer:=0; --to check the 8 bit of data
signal word: std_logic_vector(7 downto 0); --to put the data in signal
type state_type is(start_bit,check_bits,stop_bit,data_out);
signal state: state_type;
begin
process(out1,rxd)
begin
if(out1='1' and out1'event)then
case state is
when start_bit =>
if(rxd='0')then -- check start bit
state<=check_bits;
elsif(rxd='1')then
state<=start_bit;
end if;
when check_bits =>
cnt<=cnt+1;
if(cnt<8)then
word(cnt)<=rxd;
elsif(cnt=8)then
state<=stop_bit;
cnt<=0;
end if;
when stop_bit =>
if(rxd='1')then
state<=data_out;
end if;
when data_out => --this state check if the data "00111111" is recieved
if(word="00111111")then
led<='1';
else
led<='0';
state<=start_bit;
end if;
end case;
end if;
end process;
i get the data from mvme162... on hyper terminal i see words that mvme162 transmit... i need to check if the letter/char "?" is there.. if is there led<='1'... (?=00111111 in ascii).
Then you compare the received bits with a bitmask for your char. Or am I missing something?
--- Quote Start --- Then you compare the received bits with a bitmask for your char. Or am I missing something? --- Quote End --- yes... for example: the code ascii of letter "Y" is "01011001" by ascii table... and if mvme162 transmit the letter "Y" so the led<='1', but then i the code in the altera (cyclone ii) the led is always '0' and noything cahange... and i can see that mvme162 transmit.
Have you run a simulation?
Have you verified the reiceiver works as expected? I assume you always check in the middle of the bit?- Mark as New
--- Quote Start --- Have you run a simulation? Have you verified the reiceiver works as expected? I assume you always check in the middle of the bit? --- Quote End --- yes yes by c# and work perfect... i think is about a lot of bits are sent... Hmm...how do i check in the middle of the bit?
The bit takes time to send. So you need to check your bit in the middle of that duration so you know for sure what bit you read. On the edges gives inacurate readings. Also, you need to pass your signal trough a synchronizer to prevent metastability.
Back to read in the middle: Once you detected the start bit (first falling edge after stopbit) you wait half the bittime and than start reading.- Mark as New
--- Quote Start --- The bit takes time to send. So you need to check your bit in the middle of that duration so you know for sure what bit you read. On the edges gives inacurate readings. Also, you need to pass your signal trough a synchronizer to prevent metastability. Back to read in the middle: Once you detected the start bit (first falling edge after stopbit) you wait half the bittime and than start reading. --- Quote End --- how do i check i the middle? can you help me? if you can to take my code and show me how to check in the middle :) thanks
--- Quote Start --- Back to read in the middle: Once you detected the start bit (first falling edge after stopbit) you wait half the bittime and than start reading. --- Quote End --- I would use a timer for waiting, and add a state to check the timer.
--- Quote Start --- I would use a timer for waiting, and add a state to check the timer. --- Quote End --- can you show me how?
I could, but there is enough reference material on the www. Use your favorite search engine and search for VHDL Timer.
You might think about changing the clock and use the wait timer to also time the bits.
--- Quote Start --- I could, but there is enough reference material on the www. Use your favorite search engine and search for VHDL Timer. --- Quote End --- --- Quote Start --- You might think about changing the clock and use the wait timer to also time the bits. --- Quote End --- its work :) rx was connected to rx and tx was connected to tx but its work just if rx to tx and tx to rx (wires)... thank you all :)
