17258 Discussions
RTL module crashes computer
I have a purely combinatorial RTL module as part of my OpenCL pipeline. The design compiles without problems or warnings. However, when executing the program, it first stalls for a few minutes, then the entire computer hangs and requires a manual restart. I can't make sense of this because:
- Simulating the verilog itself works.
- The design has no internal states and it's stall free with a fixed (0) latency.
- Just using a simpler (but also combinatorial) design without touching any of the other code does not show the problem.
- Status flags iready/oready/ivalid/ovalid are not used (just routed through)
- The output of the RTL module just gets transferred back to the host (no further computation depends on it).
I'm using the 16.1 SDK with the DE5a-net board. Any suggestions on how to debug this would be appreciated!
Hanno
