17249 Discussions
Reading from files in Nios II simulation
I've created a simulation setup for a Nios II cpu design using SOPC Buillder and Nios II IDE to generate all of the required simulation files, converted everything to run using NCSim on a UNIX environment. I've had no trouble with the simulations or setup up to this point.
The trouble started when I wanted to write a simple test script to run on the Nios processor to read a input command file and act on the commands with that file, and then write out a log file. However, when it tries to access the file, it prints "Cannot open command input file" to the console window. Below is the C code I'm using to access the HAL file I/O:
# include <stdio.h>
# include <stdlib.h>
# include <string.h>
# include <system.h>
int main ()
FILE *infile = NULL;
FILE *logfile = NULL;
/* Open files for access */
infile=fopen("Nios_II_cpu_model.in","r");
if (infile == NULL)
printf ("Cannot open input command file!\n");
exit(1);
logfile=fopen("Nios_II_cpu_model.log","w");
if (logfile == NULL)
printf ("Cannot open output log file!\n");
exit(1);
/* Close the files */
fclose(infile);
fclose(logfile);
return 0;
Anyone have any ideas???
Tony
