17267 Discussions
Reducing number of pins to connect SDRAM
I have a design based on the 144 pin EP3C25.
I programmed a NIOS II processor with external SRAM connected to the FPGA but for this I need more than 30-pins.
In order to reduce this amount I found and EDN article in which is descibed how to multiplex the data-lines with the lower address-lines.
I have attached this article (Look for: SDRAM interface slashes pin count).
Is there someone who could help me to implement this solution in the altera sdram.vhd which is generated by the MegaWizard Plug-In Manager.
I tried to understand how the SDRAM-interface is implemented with sdram.vhd but because i am beginner using FPGA's it is still too complicated for me at this moment.
Thank you and best regards,
Wamor
