17267 Discussions
Register using component and port maps
Hi, I am building a 32 bit register using a 8-bit register as a component. However, I am stuck at port mapping the 8-bit register correctly, any tips/help would be appreciated.
my code so far:
----BITSTORAGE----
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
Use ieee.std_logic_unsigned.all;
entity bitstorage is
port(bitin: in std_logic;
enout: in std_logic;
writein: in std_logic;
bitout: out std_logic);
end entity bitstorage;
architecture memlike of bitstorage is
signal q: std_logic := '0';
begin
process(writein) is
begin
if (rising_edge(writein)) then
q <= bitin;
end if;
end process;
bitout <= q when enout = '0' else 'Z';
end architecture memlike;
----8-BIT REGISTER----
Library ieee;
entity register8 is
port(datain: in std_logic_vector(7 downto 0);
dataout: out std_logic_vector(7 downto 0));
end entity register8;
architecture memmy of register8 is
component bitstorage
end component;
begin
c0: bitstorage port map(datain(0),enout,writein,dataout(0));
c1: bitstorage port map(datain(1),enout,writein,dataout(1));
c2: bitstorage port map(datain(2),enout,writein,dataout(2));
c3: bitstorage port map(datain(3),enout,writein,dataout(3));
c4: bitstorage port map(datain(4),enout,writein,dataout(4));
c5: bitstorage port map(datain(5),enout,writein,dataout(5));
c6: bitstorage port map(datain(6),enout,writein,dataout(6));
c7: bitstorage port map(datain(7),enout,writein,dataout(7));
end architecture memmy;
---32-BIT REGISTER---
Library ieee;
entity register32 is
port(datain: in std_logic_vector(31 downto 0);
enout32,enout16,enout8: in std_logic;
writein32, writein16, writein8: in std_logic;
dataout: out std_logic_vector(31 downto 0));
end entity register32;
architecture biggermem of register32 is
component register8
end component;
begin
Implementing port map here
end architecture biggermem;
I dont see what the problem is, other than the fact that these are clearly not registers as there is no clock.
You need to instantiate 4x register8 as there are 32 bits.
