I have Quartus Pro 25.1.0.129 on my Windows 10 Pro 64-bit. I have installed, uninstalled and reinstalled some of the modules over time. These include the Agilex range and the huge EDA simlib file. When I track the disk usage in the Control Panel, Quartus doesn't update to reflect a lower disk usage when a module has been uninstalled. For example, I installed the EDA simlib to compile the libraries for a third party simulator then removed the file because it took up about 40GB of space. However, on the reported disk usage, the total amount still includes this 40GB. I have also observed that if you install the devices, remove them then reinstall them, the reported disk usage will be equivalent to double the correct usage. Is there a file that you can modify to change this to reflect the correct storage space used?
