17252 Discussions
Reset the FPGA via JTAG
Is there any tool to reset the Cyclone FPGA via JTAG (USB-Blaster) and force it to re-read the configuration from the EPCS?
Problem is: I use quartus_pgm to download a simple NIOS in the Cyclone (quartus_pgm -c USB-Blaster -m JTAG -o P;file@1). Then, I load a flash file with an FPGA configuration and NIOS application (nios2-flash-programmer --device 1 -e --base=0x802800 --program file).
If I simply use the option --go in nios2-flash-programmer, only the processor is reset; my new FPGA configuration is not loaded until I power the board off then on.
So, is there something like "quartus_pgm -c USB-Blaster -o R;@1"??? (The @1 is important as I want to individually reset the FPGAs in a JTAG chain)
Thanks in advance.
Fernando
Did you check the quartus_pgm -i option? See command line help.
Yes, thanks. But it does not load from the configuration device; it just initializes the FPGA with the currently loaded configuration.
:mad:
--- Quote Start ---
--- Quote End ---
I think, a reconfiguration request results in reloading the configuration from the hardware defined configuration source. I don't understand, how the programmer inititializes the FPGA without reloading the configuration. I thought, that it's the equivalent to the option "Initiate configuration after programming" in interactive programming.
I don't know how it works, but I have one configuration in external flash and a different one is downloaded to the FPGA via quartus_pgm ...-i. After the download is finished, the FPGA executes the downloaded one.
I decided to go the "hard way":
-quartus_pgm simple_config.sof
-nios2-flash-programmer complete_config+nios_application.flash
-quartus_pgm complete_config.sof
This way it restarts with the correct configuration.
(I need this 'restart-without-power-cycle' for production programming and testing without operator intervention).
Thanks anyway.
BR
Fernando
