17256 Discussions
Resolving Errors in hardware implementations of Agilex Board using Quartus Prime Pro 24.1
Shriraksha
I am using Quartus Prime pro 24.1 to program a AGILEX Board.
After programming the bitstream file we are getting an error message in Quartus program with log:
Error status: The device chain in Programmer does not match physical device chain. Expected JTAG ID code 0x0343B0DD for device 1, but found JTAG ID code 0xC341A0DD.
Operation failed.
When we program and configure, the progress is 0% (Failed).
We have been stuck with this error. Could you please help us to find the issue.
Thank You.
BXia
Hi Shriraksha,
I think you are using Terasic Agilex SoM board.
In your screenshot, a wrong FPGA device is selected, it's not for Agilex SoM board, and there isn't HPS device in the JTAG chain. Please follow the steps below to program the .sof again:
1. Click“Auto Detect”button on the Programmer window, then select the FPGA device associated with the Agilex SoM module board.
2. Then you should see both FPGA and HPS devices are shown in the JTAG chain. Right click on the FPGA device, click“Change File..”, select your .sof file.
3. Check the“Program/Configure”box, and then click“Start”button to download .sof file into FPGA.
By the way, please remove the sdcard from the board before programming the .sof file. And your email system seemed has issue as the email replied by Terasic was refused, it shows all your email accounts are invalid.
Farabi
"We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Thank you for your understanding."
Farabi
Hello, please refer to Terasic reply on your issue. I transferring this case back to community.
regards,
Farabi
