17255 Discussions
Results of Verilog debugging problems
the design of a level sensitive latches, input signal is d clock, the output for the q, the function is clock=1, q=d
My code is as follows, the problem is the simulation results in clock=1, q=d no problem, but clock=0 should be maintained in front of Q value, and the result is q=d; please have a look of code where the problem
module my_latch(d,clock,q);
input clock;
input [3:0] d;
output [3:0] q;
reg [3:0] q;
always
wait (clock)
begin
# 1 q<=d;
end
endmodule
module stimulus_latch;
reg CLOCK;
wire [3:0] Q;
reg [3:0] D;
my_latch MY_LATCH(D,CLOCK,Q);
initial
begin
CLOCK <= 1'b0;
forever# 20 CLOCK=!CLOCK;
end
initial
begin
# 20 D=4'D7;
# 20 D=4'D12;
# 20 D=4'D5;
# 20 D=4'D13;
# 200 $stop;
end
initial
$monitor($time ," D= %B,Q= %B ",D[3:0],Q[3:0]);
Endmodule
