17267 Discussions
RiscFree Arria10 Ashling Sample project does not build
fflores
I am trying to use one of the Ashling Sample project (Arria10-A9-Sum) from the RiscFree IDE for Intel that comes with the "Intel Quartus Prime Standard Edition" windows installation, but the project does not build and it seems like is missing a plugin since the property setting shows a 'Orphaned configuration' warning as shown in the attachments. Does anyone know how to resolve this issue? any help will be greatly appreciated.
JingyangTeh_Altera
Hi
Are you importing a sample project for the HPS or the niosV?
Maybe the link below might be useful when importing the project.
Project Import for NiosV
https://www.intel.com/content/www/us/en/docs/programmable/730783/23-4/importing-processor-project.html
Project import for HPS
https://www.intel.com/content/www/us/en/docs/programmable/730783/23-4/importing-hps-project.html
Jingyang, Teh
fflores
Hello Jingyang, Teh,
I am importing a sample project for the ARM HPS. The HPS link does not have any issues for the Agilex A53 sample which comes with a pre-built 'elf' file. However, if I apply the same steps for the Arria10 sample then the project does not compile as shown in the original post attachment(Arria10-a9-sum- Does not build.PNG) and if I go into the Arria10 Sample project  'Properties->c/c++ build->settings->Tool Settings', then it shows as blank(Arria10-a9-sum- Orphaned configuration.PNG) with an "Orphaned Configuration...." warning. and Since the project does not build then it cannot create a debug session. I was wondering if there are other steps for the Arria10 to work on RiscFree IDE. As a additional test, I did the same steps with Cyclone V sample project, which gets the same type of error.
The RiscFree IDE version that come with the "Intel Quartus Prime Standard Edition" is v23.4.1
Fernando
JingyangTeh_Altera
Hi Fernando
Sorry for the late response.
Regret to inform you that currently the Ashling IDE only supports debugging feature for the SOC.
For building a sample project you would need to stick back to using the Arm Development IDE.
Building sample project in ArmDS.
https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Exercise_Sample_Application
Debugging on Ashling IDE
https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/Debugging-SoC-FPGA-with-RiscFree-IDE/m-p/1597064#M2561
Jingyang, Teh
JingyangTeh_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
