17263 Discussions
Rx SerDes PLL must be driven by compensated input ERROR
I'm trying to drive the input clock of the a megawizzard-created Rx SerDes using the output clock of another PLL, and I get the following Fitter Error:
"Input clock pin of fast PLL <name>, which drives at least one non-DPA-mode SERDES, must be driven by a compensated input."
Here are my PLL and SerDes instantiations:
wire Clk125MHz;
DataClkPll DataClkPll_inst(
.areset ( PllResetStrobe ),
.inclk0 ( DataClkIn ),
.c0 ( Clk125MHz ),
.locked ( DataClkPllLocked )
wire RxSerDesClkOut;
wire RxSerDesPllLocked;
wire [111:0] RxDataWide;
RxSerDes RxSerDes_inst(
.pll_areset ( PllResetStrobe ),
.rx_in ( {DataPort1,DataPort0} ),
.rx_inclock ( Clk125MHz ),
.rx_locked ( RxSerDesPllLocked ),
.rx_out ( RxDataWide ),
.rx_outclock ( RxSerDesClkOut )
Basically, I'm using the separate PLL to fine tune data/clock timing in my system (I intend to add in dynamic phase programming later). It seems like Quartus is complaining that I'm not using a dedicated clock input pin to directly drive the Rx SerDes.
But I've done this sort of thing before using Quartus II v4 with a Stratix I part. I found a patch at that time to get around this problem, which included placing a "quartus.ini" file in the directory, with the compiler switch:
FYGR_ALLOW_NONIO_CLKIN_TO_RXPLL = on
Now I'm using Quartus II v8.1 with Stratix III, and the quartus.ini file doesn't fix the compiler error message any more.
Is there another solution for Quartus II v8.1/Stratix III for this situation?
Ron
Is Clk125MHz a compensated clock output? See Page 0 of PLL wizard.
Yes, PLL is configured for "Normal Mode", feedback inside PLL.
