17249 Discussions
SISO testbench and waveform HELP
Hello, i am new to VHDL and i want some directions.
I want to make a Serial in serial out 4 bit shift register, but my waveforms in output have some red marks as you can see below.
https://alteraforum.com/forum/attachment.php?attachmentid=15351&stc=1
I am posting my testbench too. I d be grateful if you help me with that, because i am doing a project at the university.
ENTITY Siso_Tb IS
END Siso_Tb;
ARCHITECTURE behavior OF Siso_Tb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT Siso
PORT(
Sin : IN std_logic;
clk : IN std_logic;
reset : IN std_logic;
enable : IN STD_LOGIC;
Sout : OUT std_logic);
END COMPONENT;
--Inputs
signal Sin : std_logic := '0' ;
signal clk : std_logic := '0';
signal reset : std_logic := '0';
signal enable : std_logic := '0';
--Outputs
signal Sout : std_logic := '0';
-- Clock period definitions
constant clk_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: Siso PORT MAP (
Sin => Sin,
clk => clk,
reset => reset,
enable => enable,
Sout => Sout);
-- Clock process definitions
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
clk_enable :process
begin
enable <= '0';
enable <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
reset <= '1';
reset <= '0';
Sin <= '1';
Sout <= '0';
wait for clk_period;
Sin <= '0';
Sout <='0';
Sin <= '0';
Sout <='1';
Sin <= '1';
Sout <='0';
Sin <= '0';
Sout <='0';
Sin <= '0';
Sout <='1';
end process;
END;
You're driving Sout in the testbench, and the UUT is also driving Sout. Only the UUT should be driving SOut.
--- Quote Start ---
--- Quote End ---
You mean i should not change the values of Sout in the process? When i do it Sout is always 0.
SOUT is an output from the UUT. Therefore the UUT sets the value of Sout. If it is always 0, then there is a problem with the UUT, or th way you're driving the UUT.
The X values occur because you are driving '1' against the value of '0' from the UUT.
I also notice you are generating enable like a clock. and therefore likely never actually enabling the UUT. It needs to be set for full clock cycles, not half cycles.
