SOF file checksum
Hi all,
I want to inject Single Event Upsets (SEU) into cyclone II FPGA ... i want to make some bit flips in SOF file and download the corrupted bit file to Cyclone II FPGA ... but the programmer does not allow this and responds with a message "This device is not supported" .... I know that this is because of the checksum violation... Can anybody suggest answers to the following
1- where in the SOF file the 32 bit checksum is located?
2- how to recompute the checksum ?
3- what is the value of 32 bit generator polynomial for CRC?
Or any other alternative method for injecting faults in altera FPGAs
Kind Regards
Hello
You can find the information you are requiring in the CycloneIII Handbook
Chapter 11. seu mitigation in the cyclone iii
device family
1 - Quartus adds a 32bit pre-calculated CRC value at the end of sof file. This file is located to your project directory.
Also, a 16bit CRC is added in each CRAM frame.
2 - You are not able to recompute the checksum.This is automatic calculated by the Hard logic circuit in the fpga.
3 - I think that you can read the 32bit CRC register via your jtag interface
Thank you
Dimitrios Agiakatsikas
--- Quote Start ---
Hello
device family
Thank you
--- Quote End ---
how about rbf ?
how can i figure out what is the data mean in the rbf file ?
