17255 Discussions
SOF-file works correctly, POF-file does not
I made the simplest of the simplest NIOS II
applications: a LED that blinks endlessly. I
have a SOF- and POF-file created by Quartus
Prime 16.0.0.
Programming the SOF-file and running the
NIOS II application results in a continuously
blinking LED. However, programming the
POF-file and power cycling the MAX 10
development board gives a LED that blinks
for about one second. After that it stays
lit.
Any clues?
[ Solution: apparently it is due to printf statements
in the NIOS C-code. Removing them solved the problem. ]
Jos
