SOPC Builder GUI Problem
I am running Quartus II version 7.2 and SOPC Builder 7.2 on Ubuntu 8.04. I tried to launch the SOPC Builder from Quartus and I find it that the SOPC main window is blank. However, I can still navigate to the menus (from memory) and have pop-up windows show up. I have attached an image of this as follows.
http://img244.imageshack.us/my.php?image=screenshotyc2.png
FYI, I have updated my Java Runtime. At first I ran this with Quartus II 7.2 sp3 and I thought the sp3 might be causing problems, so I removed the entire Quartus directory and installed again but without the sp3. However, the problem persists.
I can run things fine with the SOPC Builder classic but I find that very hard to use. Therefore, if any1 has any ideas on how to resolve this, please let me know.
The easiest method to resolve these issues is to use an operating system supported by Altera. Ubuntu is not one of them. Look I'm a Linux guy too but at some point we have to stop hacking and get some work done.
Jake
--- Quote Start ---
Jake
--- Quote End ---
Thank you for your post. But I would really like to keep my current configuration. I will probably fall back to Windows if nothing else works.
--- Quote Start ---
--- Quote End ---
Or if you really want to keep Linux and use Quartus II (without buying the supported but paid distros like RHEL), use a fully-RHEL-compatible distro like CentOS. Everything in Quartus works fine in CentOS. You can also install Quartus on a Virtual Windows/CentOS Machine on your Ubuntu sustem and then use it.
I'm using Ubuntu 8.04 and Quartus 8.0 sp1 with patch 137 installed.
I just installed the patch because the GUI suddenly stopped working.
I tried lots of tips to get the GUI going again, now in the end I found that the mainwin toolkit used by altera stores a lot of stuff in ~/.mw.
After simply doing a rm -rf .mw, quartus started up again without problems.
@jakobjones:
I don't see the point of switching my linux distribution.
As i need to get stuff done, too, I can't change my distri for every tool I use.
modelsim, ise, etc. are working on Debian/Ubuntu. So if they can handle it, so Altera should be able to do this, too?
Ok, I could put the whole quartus stuff in a virtual machine. I don't know if that helps the performance though.
Maybe Altera should use a different GUI-Toolkit ;-) I use Qt, and have no problems writing software that supports Linux/Windows equally without shipping tons of MSWindows emulation stuff.
Cheers, Alex
