SOPC Builder error
Hi all,
I'm new on using SOPC Builder in Quartus II (10.1) on a DE2 board (cyclone2).
I was trying to run an old tutorial(the one that i find in the DE2 cd) ,in order to understand how to use SOPC,that implement a nios2/e with 2 PIO(input-8switch, output-8LED),jtag uart and a ram.. but i have a problem in generating file in SOPC builder; the error that stops the generation is
"PIO inputs are not hardwired in testbench. undefined values will be read from PIO inputs during simulation"
Someone can help me to go on with that?
Hi:
Dont worry, that's not an error, it's just a warning, you can continue working in the NIOS II IDE with the system created from SoPC Builder.
However, if the system generations stops, it has to be other thing. If you want, paste here the messages shown in the SoPC to see them and maybe help u.
Hi, thanks for you answer
it wasn't a warning, was an error that stopped the system generation. But i solved it! I had to put a check in the checkbox at the bottom of the window of PIO input to hardwire it!
