Hi, I'm trying to use a SOPC Builder system for two projects located in two different directories, so I need to explicitly tell Quartus the paths to the source files so that it can find them. I'm trying to use the auto-generated .qip file for the SOPC Builder system, but for some reason it's almost completely empty! It doesn't list any of the .vhd or .v files for my system, only a few miscellaneous files:
# clk
# tri_state_bridge_0
# cfi_flash_0
# timer0
# jtag_uart_0
# cpu_0
set_global_assignment -name SDC_FILE
set_global_assignment -name SOURCE_FILE
# sysid
# watchdog_timer
# altmemddr_0
# null
set_global_assignment -name SOPC_BUILDER_SIGNATURE_ID ...
I tried using Qsys instead but it can't generate my system at all. :/ Does anyone know how to make SOPC Builder generate a correct .qip file?
I remember the fact the qip file doesn't list the source files is a known issue/feature and it was discussed in the forum some time ago for Quartus version 9.0. This is also the reason you had a lot of warnings (sort of "hdl file not included in project") during project compilation.
I think your problem is related to this: you need to have the qip file and the sopc builder auto generated hdl files in the same directory of your project, so that Quartus can find them anyway. Unfortunately I don't know if there is a workaround, apart manually copying the required sopc files in both projects.- Mark as New
For anyone else experiencing this problem, I ended up working around it by writing a TCL script that generates the appropriate assignments from the PTF when the QIP is loaded
I created a util_qip_from_ptf.tcl file containing:proc util_qip_from_ptf {filepath} {
set fp
lappend map __PROJECT_DIRECTORY__
while { >= 0} {
if {*Synthesis_HDL_Files = "(.*)";$} $line {\1} line]} {
foreach hdl_file {
set hdl_file ]
if { ".vhd"]} {
set setting_name VHDL_FILE
} elseif { ".v"]} {
set setting_name VERILOG_FILE
} else {
puts "Ignoring unknown HDL file type: $hdl_file"
continue
set_global_assignment -name $setting_name $hdl_file
and I made my own fake .qip file containing: set_global_assignment -name IP_TOOL_NAME "Fake QIP File"
set_global_assignment -name IP_TOOL_VERSION "1.0"
source
util_qip_from_ptf
thanks for sharing!
