17268 Discussions
SOPC PLL module waring
Everybody, I use SOPC Builder to generate the altpll, but the builder show this warning and not generate the Altera's IP, name is "xxx.qip" and Quartus compilter the nios's ip show the message,
"Error (10130): Verilog HDL error at altpll.v(221): parameter "clk0_divide_by" is not a formal parameter of instantiated module"
and sopc builder show the "Warning : Warning: Entity "altpll" obtained from"/users/johnny/documents/quartus/de2_70/altpll.v" instead of Quartus II megafunction library"
who can help solve this problem?
many thanks
I'm having the same issue. Anyone have a solution?
Running Quartus 10.0 on XP SP3. The altpll was instantiated as part of the SOPC builder and I instantiated it in my main Verilog file, which was created through the DE3 System Builder.
-Jason
i am able to add an Avalon ALTPLL to my SOPC Builder system and do a full compile (QII 10.0). can you provide some more information (target device, PLL settings)
