17255 Discussions
SOPC builder command line
I'm trying to create a makefile for my project. This makefile should also regenerate the SOPC system. However when I try the following command (windows xp, cygwin):
"sopc_builder --generate --classic avalon_if.ptf"
the "avalon_if.vhd" and the "sdram_0.vhd" files are generated but not the other components (PCI bridge, irq controller...).
There is a big difference is the output of the SOPC builder gui and the command line output:
The command line output starts with: "mk_custom_sdk starting"
The GUI starts with: "info: pci_compiler_0: Instantiating pci_mt32 MegaCore function."
The gui must be doing something before the actual system generation but what and how can I do this via the command line?
thanks,
Jo
Quartus behaviour is different on a linux system then on a windows (cygwin) system. The same command produces different results:
From the Makefile:
sopc_args = --no_splash --generate=1 -s $(sopc_system).sopc
$(sopc_system).vhd: $(sopc_system).ptf
sopc_builder $(sopc_args); if [ $? = 4 ]; then exit 0; else exit 1; fi
In linux all files are generated ok, in windows only the $(sopc_system).vhd is generated.
The ultimate goal is to have a script(makefile) that download my project from a versioning sytem (svn) and then builds the complete project including all code generation.
My findings for Q10.1:
There is some progress: when issuing the command :
sopc_builder --generate --nosplash
It will build your system both in windows(cygwin) and linux (ubuntu). However... apparently there are still components that need a display to connect to. This means you can still not generate everything on a headless system. The pcie generator throws a 'headless exeption' because it relies on some java awt libraries. I hope this will get cleaned up in one of the next versions.
In the mean time you could start a (virtual) x server:
export display=:1
xvfb :1&
Does anyone have a better solution?
