17268 Discussions
SOPC error: non-installed megacores
Hi.
When I try to generate SOPC module, I see message " The MegaCore IP Library must be installed before the system can be generated".
I use Quartus 7.2 SP1.
I didn't see any MegaCore packs on the Altera web-page that should be installed.
Alse, I pointed the library C:\altera\72sp1\quartus\sopc_builder in Tools->Options->IP search path
How can I solve this problem ?
Thans
For a successful install you need to install:
Quartus 7.2
Quartus 7.2 Sp1 (now at SP2 by the way)
MegaCore IP Library 7.2
MegaCore IP Library 7.2 Sp1 (now at SP2 as well)
optionally
NIOS
ModelSim
Yes, thank you.
