STD_LOGIC_VECTOR error
I'm trying to implement following verilog peace of code in vhdl
reg [11:-2]center;
it's clear center is an 14 bit register. but in vhdl
signal center : std_logic_vector(11 downto -2) gives me an error.
what should i do ?
i know that std_logic_vector type cannot use to index negative values.
please help me.
use
std_logic_vector(13 downto 0) and offset everything by 2.
Not really any other way around it for std_logic_vector.
Why has the value got -ve indices? is it a fixed point value. The fixed point types allow negative ranges as they provide bit that represent numbers that are 2^N (ie. -ve indeces are to the RHS of a decimal point:
signal centre : ufixed(11 downto -2);
thank you for the quick reply sir,
what if i used following code instead using std_logic_vector
signal center: integer range 0 to 16384 -- (13 downto 0)
will it be the same ?
Why do you need negative index? Write more details what your code does with "center" signal.
i'm trying to design a game using vhdl. an original source for this game was found in verilog. in that they used this negative indexing inside reg. i tried to chnage the reg indexing as reg[13:0] and game did'nt worked. original verilog code as follows
// Used for drawing, moving and updating of walls
module walls(
input clk,
input update,
input [5:0]data,
output wire hold,
output wire [5:0]data_addr,
input [2:0]quadrant_collision,
input [9:0]radius_collision,
input [2:0]quadrant,
input [9:0]radius,
input reset,
input [1:0]difficulty,
output reg [2:0]quadrant_out,
output reg visible,
output reg island,
output reg visible_collision
reg [5:0]walls[0:127];
reg [11:-2]center;
reg [6:0]write_ptr;
wire [11:0]offset = center[11:0] + radius;
wire [11:0]offset_collision = center[11:0] + radius_collision;
integer i;
always @(posedge clk) begin
if(reset) begin
center <= 14'd6144;
end else if(update) begin
case(difficulty)
2'd0: center <= center + 14'd6;
2'd1: center <= center + 14'd9;
2'd2: center <= center + 14'd12;
2'd3: center <= center + 14'd15;
endcase
end
end
quadrant_out <= quadrant;
if(radius < 10'd28) begin
visible <= 1'b0;
visible_collision <= 1'b0;
island <= 1'b1;
end else if(radius < 10'd32) begin
visible <= 1'b1;
island <= 1'b0;
end else begin
visible <= walls[offset[11:5]][quadrant+:1];
visible_collision <= walls[offset_collision[11:5]][quadrant_collision+:1];
island <= 1'b0;
end
end
assign data_addr = write_ptr[5:0];
assign hold = write_ptr[5:0]!=6'd0 || (write_ptr==7'b0000000 && center[11]) || (write_ptr==7'b1000000 && !center[11]);
if(reset) begin
write_ptr <= 7'b1000000;
for (i=0; i<128; i=i+1) walls[i] <= 6'b000000;
end else if(hold) begin
walls[write_ptr] <= data;
write_ptr <= write_ptr + 7'd1;
end
end
endmodule
--- Quote Start ---
--- Quote End ---
Did you also offset all of the constants and additions and assignments that take place on center? everything needs to be left shifted by 2.
--- Quote Start ---
--- Quote End ---
Almost, I think you mean:
signal center : integer range 0 to 16383;
As this is 14 bits. 16384 requires 15 bits.
But you still have the same problem as I outlined above - you need to offset everything else, not just the center signal.
