17255 Discussions
Setting programming file name?
Does anyone know how to set the name of the generated programming file in Quartus? I'm using the RBF file format and it seems to default to <project_name>.RBF. Can this be changed?
--- Quote Start ---
--- Quote End ---
I will just rename it
I reviewed Quartus Settings File Reference Manual, and there isn't such a setting there.
You can change project output directory using PROJECT_OUTPUT_DIRECTORY, or turn on/off RBF file generation using GENERATE_RBF_FILE, but not change the file name.
Evgeni
