Hi All,
I want to tap (insert to SignalTap-II) the tristate/bidirectional pins... I understand that SignalTap-II doesn't support this feature, only flops/buffers that drive these pins could be tapped... The issue is so I need to tap the signals coming from the HPS generated code (I2C and GPIO signals)... So, how can I find the flops/buffers, which drive these signals? Thank you連結已複製
2 回應
--- Quote Start --- Hi All, I want to tap (insert to SignalTap-II) the tristate/bidirectional pins... I understand that SignalTap-II doesn't support this feature, only flops/buffers that drive these pins could be tapped... The issue is so I need to tap the signals coming from the HPS generated code (I2C and GPIO signals)... So, how can I find the flops/buffers, which drive these signals? Thank you --- Quote End --- Dear All, I'm also interested in this topic. I want to signal tapping HPS I2C0 bidirectional signals by preserving HPS-side pin assignments. Is there any progression in this thread? Regards, Zsolt
