17267 Discussions
Signaltap State-Based Triggering Flow
i've read this page: http://www.altera.com/support/examples/on-chip-debugging/signal-tap/signaltap2-design-examples.html and the Handbook.
But I've still two questions.
When is a flag or a counter updated, if I set a flag or e.g. increment a counter.
Is the behavior like a variable or like a signal in VHDL. Combinational or Clocked?
Can I use start_store stop_store as a Storage Qualifier?
like this, it should store two samples, which can be in two ore more clock cycles
state DStore: begin if (condValid) begin start_store; stop_store; set iq; if (iq) //store I and Q sample begin goto SkipWords; clear iq; end // set iq; end end
Thank you!
Best regards
Malte
I find it just easier to add detection logic in your RTL. Then you know for sure when odd conditions over several clock cycles have occured.
You can use the syn_keep attributes on registers so you can then connect them to signaltap.
