17268 Discussions
Simple explaination I hope
I have seen some VHDL code written like this:
SIGNAL slv : STD_LOGIC; SIGNAL usg_counter : UNSIGNED(7 DOWNTO 0); --code to make usg_counter count up 1 count etc. every 1uS here proc_ConfusedDotCom : PROCESS(usg_counter) BEGIN slv <= '0'; IF usg_counter = b"0010_0110" THEN slv <= '1'; END IF; END PROCESS proc_ConfusedDotCom;
Can some clever bod explain exactly what is happening to the signal 'slv' here please? Is there a better way of writing this?
I know what is does, I would like to know why. :)
Cheers,
Andy
--- Quote Start ---
Cheers,
Andy
--- Quote End ---
it is equivalent to
IF usg_counter = b"0010_0110" THEN slv <= '1'; else slv <= '0'; END IF;
or just:
slv <= '1' when usg_counter = b"0010_0110" else '0';
In your code the '0' is assigned as default and the next conditional statement updates it.
Cool!
Your equivalent 'else' answer is what I thought too, but thought (like many things) there may be deeper VHDL 'nastiness' to consider too.
Andy
The default approach is convenient alternative if the target signal is to be assigned same value in many following statements in the sequence.
The most common usage is in state machines where output signals are usually the default, but assigned something different in specific states.
Gotcha.
OK, another question leading on from this then if I may:
As you can see, the above process is processed upon a change to usg_counter
Now say I combined the activity of slv into the clocked process that deals with updating the counter, i.e. something like this:
proc_Counters : PROCESS(IN_CLK, IN_RESETn) BEGIN IF IN_RESETn = '0' THEN usg_Counter <= (OTHERS => '0'); slv <= '0'; ELSIF RISING_EDGE(IN_CLK) THEN IF usg_Counter = b"0010_1111" THEN usg_Counter <= (OTHERS => '0'); ELSE usg_Counter <= usg_Counter + 1; END IF; --Put it here instead... IF usg_Counter = b"0010_0110" THEN slv <= '1'; ELSE slv <= '0'; END IF; END IF; END PROCESS proc_Counters;
Would that do the same thing?
Andy
yes, but it has a 1 clock cycle delay compared to the unregistered code.
REALLY!
Hmmmmmmmmm!
Hold on, which has a 1 clock cycle delay. The combined one or the separate process one. The latter I guess.
Cheeers,
Andy
the get the same behaviour, you need to make the counter a variable, check the variable rather than the signal.
the combined one has the extra clock cycle delay, as you make slv synchronous. The seperated one has no interaction with the clock.
I see!
Effective change within a process only implemented after the process is done.
Thank you yet again!
no, this is to do with the way signals vs. variables work.
signals are updated only when the process they are assigned in suspends. So a signal assignment actually schedules the update to occur in the next delta cycle, or in x ns if you use the after assignments:
x <= '1' after 10 ns;
varaibles are updated immediatly, hence why making the counter a variable instead of a signal would remove a clock delay from the process. It wouldnt exactly recreate the same hardware, as the two versions would alter the position of the output register - with separate processes the register is on the counter with the slv signal just a gated version of this register output. In the combined version, the slv is a gated version of the +1 output, with the register placed after this.
Hence why you really need to understand the underlying hardware before writing the VHDL.
