17255 Discussions
Simulating Jtag-Uart as an input
I'm simulating an SOPC design that includes a NIOSII and a Jtag-Uart with Modelsim.
My problem is that I can use the Jtag-Uart as a program output, but not as an input.
To go into details, SOPC Builder automatically creates:
- jtag_uart_output_stream.dat (empty output stream)
- jtag_uart_input_stream.dat (example input stream)
- jtag_uart_log.bat (example script that seems to redirect the Jtag-Uart ouput to the file jtag_uart_output_stream.dat)
When using the example script during simulation, a console appears, and I can see the characters sent by the NIOS program being displayed.
Now I don't know what to change in the example script to allow the console (or the file jtag_uart_input_stream.dat) to be used as an input to the program.
Has any of you done that before?
Thanks in advance!
Jean-Christophe
I also cannot get JTAG UART input to work in ModelSim. Altera does not seem to provide usable information on that subject.
Have you made any progress yet?
--- Quote Start ---
--- Quote End ---
I'm under the impression, that they clearly declared all virtual JTAG functionality as unsupported in simulation. I think, the only solution is to write a special component replacing the JTAG UART for simulation purposes.
