can anyone tell me the steps to follow in order to simulate my vhdl test bench with modelsim-altera? I had type my test bench with Quartus II and save the file.
1. Create your waveform vector file in Quartus II
2. Export this file to vhdl test bench (file->export) 3. Click, asssigments->settings->EDA tool settings->Simulation , choose modelsim altera. chooose compile test bench in native link settings panel, click test benches, click new, chosse any name for test bench, in test bench entity write: <your_top_level_entity>vhd_vec_tst in instance name write : i1 chosee the file generated in step 1 in test bench files. 3. Compile your project. 4. click, tools->eda simulation tools: run eda rtl simulation for functional simulation or run eda gate level simulation for timing simulation. After this steps quartus ii opens modelsim an starts the simulation.- Mark as New
thx for the replay. I can simulate the test bench already but when i want to view the waveform in wave window on modelsim, the wave windows appear but is blank didn't have anythings at all... what I should do to view the simulation on the waveform windows?
I get the following message in the transcript panel:
# Invalid time string specified: # Could not find Wave window Invalid time string specified:- Mark as New
Did you export the .vwf file into .vht ?
No. I didn't export anythings. can you tell me what I have to do inorder set the wave window to the default setting? thx file:///C:/DOCUME%7E1/XP/LOCALS%7E1/Temp/moz-screenshot-3.jpg
The image link is dead
Sorry. I have attach the pictures. the 1st picture is the view of the wave window. the 2nd one is the view of wave window preferences. It is disable. so I think I maybe some how have changes the setting of the software so causing the wave windows didn't show anythings. how to restore the default setting of the modelsim? I reinstall the modelsim but the problem still occur...
please post your test bench file and your .vwf file
here is my test bench :
LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE WORK.pipeline_package.ALL; ENTITY register_file_tb_ent IS END register_file_tb_ent; ARCHITECTURE register_file_tb_arch OF register_file_tb_ent IS COMPONENT register_file_ent PORT( pd_read: IN std_logic; pd_source1: IN register_type; pd_source2: IN register_type; clock: IN std_logic; flush: IN std_logic; ex_store: IN std_logic; ex_destination: IN register_type; ex_data: IN std_logic_vector(31 downto 0); source1_data: OUT std_logic_vector(31 downto 0); source2_data: OUT std_logic_vector(31 downto 0) ); END COMPONENT; SIGNAL pd_read: std_logic; SIGNAL pd_source1: register_type; SIGNAL pd_source2: register_type; SIGNAL clock: std_logic:= '0'; SIGNAL flush: std_logic; SIGNAL ex_store: std_logic; SIGNAL ex_destination: register_type; SIGNAL ex_data: std_logic_vector(31 downto 0); SIGNAL source1_data: std_logic_vector(31 downto 0); SIGNAL source2_data: std_logic_vector(31 downto 0); CONSTANT CYCLE : TIME := 50 us; BEGIN DUT: register_file_ent port map( pd_read, pd_source1, pd_source2, clock, flush, ex_store, ex_destination, ex_data, source1_data, source2_data); clock <= NOT clock AFTER CYCLE/2; PROCESS BEGIN flush <= '0'; pd_read <= '0'; pd_source1 <= reg0; pd_source2 <= reg0; ex_store <= '0'; ex_destination <= reg0; ex_data <= ZERO; wait for CYCLE; ex_store <= '1'; ex_destination <= reg0; ex_data <= "00000000000000010000000001010001"; wait for CYCLE; ex_store <= '1'; ex_destination <= reg1; ex_data <= "00000000000000000000000000000001"; wait for CYCLE; ex_store <= '0'; pd_read <= '1'; pd_source1 <= reg0; pd_source2 <= reg1; wait for CYCLE; ex_store <= '0'; pd_read <= '1'; pd_source1 <= reg0; pd_source2 <= reg1; wait for CYCLE; END PROCESS; END register_file_tb_arch; CONFIGURATION register_file_tb_config OF register_file_tb_ent IS FOR register_file_tb_arch FOR ALL : register_file_ent USE ENTITY WORK.register_file_ent(register_file_arch); END FOR; END FOR; END register_file_tb_config; What is a .vwf file? I can not find it at the source folder. is it generate automatically when we compile the vhdl file?- Mark as New
--- Quote Start --- I get the following message in the transcript panel: # Invalid time string specified: # Could not find Wave window Invalid time string specified: --- Quote End --- I did have excatly the same problem just like yours. I am using ACTEL Libero and ModelSim Actel to do the wave simulation the thing is, as soon as I open the ModelSim, after some compiling, there is always an error message appeared on the transcript window:# invalid time string specified then the wave window is just blank can someone here tell me whats going on with the software?:(
please keep discussion to Altera related products on the Altera Forum
thanks- Mark as New
--- Quote Start --- 1. Create your waveform vector file in Quartus II 2. Export this file to vhdl test bench (file->export) 3. Click, asssigments->settings->EDA tool settings->Simulation , choose modelsim altera. chooose compile test bench in native link settings panel, click test benches, click new, chosse any name for test bench, in test bench entity write: <your_top_level_entity>vhd_vec_tst in instance name write : i1 chosee the file generated in step 1 in test bench files. 3. Compile your project. 4. click, tools->eda simulation tools: run eda rtl simulation for functional simulation or run eda gate level simulation for timing simulation. After this steps quartus ii opens modelsim an starts the simulation. --- Quote End --- I do step by step follow your introduction. When I run eda rtl simulation or functional simulation, I met a lot of problem: This is error:
Error: Compilation of design file Counter.vho was NOT successful
Error: ModelSim: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003
Error: ModelSim: -- Loading package standard
Error: ModelSim: ** Error: (vcom-19) Failed to access library 'cycloneii' at "C:/Modeltech_5.7d/win32/../altera/vhdl/cycloneii".
Error: ModelSim: No such file or directory. (errno = ENOENT)
Error: ModelSim: ** Error: Counter.vho(29): Library cycloneii not found.
Error: ModelSim: -- Loading package std_logic_1164
Error: ModelSim: ** Error: Counter.vho(31): Unknown identifier: cycloneii
Error: ModelSim: ** Error: Counter.vho(33): VHDL Compiler exiting
Error: ModelSim: child process exited abnormally
Error: NativeLink simulation flow was NOT successful
Error: For messages from NativeLink scripts, check the file D:/Quartus_code/Quartus5/Countertest/quartus_nativelink_simulation.log
This is log file:
Info: Start Nativelink Simulation process
Info: Initialization of EDA simulation settings was successful
========= EDA Simulation Settings =====================
Family : CYCLONEII
Quartus root : c:/altera/quartus50/bin/
Quartus sim root : c:/altera/quartus50/bin/../eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : vhdl
Version : 87
Sim Output File : Counter.vho
Sim SDF file : Counter_vhd.sdo
Sim dir : simulation\modelsim
Info: Changed to directory simulation\modelsim ...
Info: Current directory is : D:/Quartus_code/Quartus5/Countertest/simulation/modelsim
Info: Running ModelSim-Altera software
Info: VHDL script : c:/altera/quartus50/bin//modelsim_vhdl.tcl
Info: Initialization of NativeLink successful
Info: Initialization of EDA advanced simulation settings was successful
Info: Creating directory modelsim_work for VHDL simulation
Info: Compiling design file Counter.vho
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: CHILDSTATUS 3836 2
Nativelink TCL script failed with errorInfo: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003
while executing
"exec vcom $cmp_opts -work modelsim_work $src "
This is my code (just a simple counter up)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
entity counter is
port (result : out std_logic_vector(7 downto 0);
clk : in bit;
reset : in bit);
end;
architecture only of counter is
signal count : std_logic_vector(7 downto 0);
begin
process(clk,reset,count)
begin
if (reset ='1') then
count <= x"00";
elsif clk'event and clk = '1' then
count <= count + '1';
end if;
result<=count;
end process;
end only;
and EDA setting I attached in this post. Could you help me solve this problem. thank you very much best regards
use unsigned type for your count and assign initial value.
signal count : unsigned(7 downto 0) := x"00"; use count + 1 instead of count + '1'; result <= std_logic_vector(count); by the way your code infers extra 8 registers unneccessarily- Mark as New
Thank you very much. I try it now.
Try numeric_std library instead of std_logic_signed.
--- Quote Start --- Try numeric_std library instead of std_logic_signed. --- Quote End --- I'm sorry. if you use "unsigned(7 downto 0) := x"00"". You can not use numeric_std. It will be error when you compile in Quartus. Please help me
Have you deleted both packages std_logic_arith and std_logic_signed from your code?
unsigned(7 downto 0) := x"00" is perfectly legal code with numeric_std.- Mark as New
--- Quote Start --- Have you deleted both packages std_logic_arith and std_logic_signed from your code? unsigned(7 downto 0) := x"00" is perfectly legal code with numeric_std. --- Quote End --- I'm sorry. I made a mistake. I had checked it. I do with QuartusII version 5.0 and Modelsim SE PLUS 5.7d. With QuartusII it is ok. But with Modelsim it still has error. I send this file to you and hope you help me to solve this problem. Thank you very much This is the error it notice me in Modelsim --- Quote Start --- # do Counter_run.do # vsim -sdftyp /i1=Counter_vhd.sdo work.<counter>vhd_vec_tst # ** Error: (vsim-3170) Could not find 'modelsim_work.work.<counter>vhd_vec_tst'. # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./Counter_run.do PAUSED at line 1 --- Quote End ---
modify the counter_run.do to:
vsim -sdftyp /i1=Counter_vhd.sdo work.counter_vhd_vec_tst add wave * run 100ns if this file is auto-generated, there is a problem somewhere in the auto-generation.- Subscribe to RSS Feed
