I hope someone has been down the path I'm on and can shed some light on my problems. I have been following the instructions found on: performing a functional simulation with the modelsim software. (http://www.altera.com/support/software/nativelink/simulation/modelsim/eda_pro_msimfull_func_sim.html) I am trying to simulate a firmware design incoporating a filter whose coeffecients are stored in an altsyncram component. I want to simulate my design using the coeffecients stored in my .mif file. Following the instructions cited above, I exported a .rif file. At this point, the instructions I get lost:confused: . My project is written in VHDL. I do not know what is meant by 'add the parameter LPM_FILE = "<memory>.rif" to the top level of your test bench or design file'. I have a number of other issues that take place after this particular hang up, but I don't think they are worth investgating until I know how exactly to make ModelSim know to find my coeffecient.rif file. Thanks in advance.Link Copied
I don't know all possible options with memory initialisation files, I always used *.hex files (also declared with altsyncram instance respectively in Megawizard). The *.hex file had to be placed in ModelSim project top (where modelsim.ini is located). Always exciting, if ModelSim gets it all!
Thank you for the hint of putting the file in the same directory as the .ini. I will be sure to do that. I am still confused as to the 'parameter LPM_FILE = "yaddayadda.rif"' or similar command that I need to add to my source in order for ModelSim to see it.
