Simulation Error
Hi, all:
I encoutered a problem --- when I do RTL simualtion, it shows a warning:
Warning : Invalid transition to 'X' detected on PLL input clk. This edge will be ignored.
Time: 0 Instance: Test_vlg_vec_tst.i1.ClkConv.altpll_component.pll0.n1
Error: (vsim-3601) Iteration limit reached at time 0 ps.
I just have an initial block to simulate the external clock input. So what's the problem. Please give me some clues. Thank you very much!
Check that you don't have two sources for the pll input clock, such as two different processes.
Hi, Daixiwen:
Thanks for the reply. I found the error was caused by the unit of timescale. I change 1ps to 1ns, and the error vanished.
