Simulation Freezing
I'm trying to simulate a code written in Verilog in Quartus using ModelSim but whenever it wants to simulate the code I see the whole software freezing. I tried reinstalling the software but it did not help. Does anyone know what could be the cause of this issue?
Thanks!
Check your verilog.
If you have a simulation loop with no time step, the simulator will get stuck trying to toggle the signals, with no increase in time.
Some classic examples are a forever loop for clock that has no time delay in it, or a counter that has nothing that gates the counting once it starts. (IE it's in a always @ (*) block)
Pete
--- Quote Start ---
Check your verilog.
Pete
--- Quote End ---
I am having the same issue, but I am designing it schematically. Any recommendations?
Do you have registers around all feedback paths like counters?
That would be the classic example. if you have sum = sum + 1 type of logic, but no register in the path, it will cause the simulator to loop for ever.
so sum_c = sum_r + 1 should work if sum_r is the registered version of sum_c. Now it will only step at the clock rate.
Pete
