17258 Discussions
Simulation Libraries for Cadence Xcelium not available in Altera Quartus 19.1 Standard
ashishk1
Hi ,
I am using ALtera Quartus Prime Standard Edition 19.1 for Arria 10  device.
With the tool, I am trying to generate testbench for my Qsys system, having all altera IPs.
When I am trying to Simulate in Cadence Xcelium, I am getting following error.
xmelab: *E,CUVMUR (/home/videopath_tb/alt_vip_tpg_multi_scheduler_191/sim/test_frame_videopath_alt_vip_tpg_multi_scheduler_191_esxktaq.sv,75|28): instance 'test_frame_videopath_tb.test_frame_videopath_inst.interlaced_tpg.scheduler.tpg_multi_scheduler_inst' of design unit 'alt_vip_tpg_multi_scheduler' is unresolved in 'test_frame_videopath_tb_alt_vip_tpg_multi_scheduler_191.test_frame_videopath_alt_vip_tpg_multi_scheduler_191_esxktaq:module'.
) core_0 (
Also in the installtion directories unbder eda/sim_lib/ I did not see any Cadence related folder .
Is there any way to generate Cadence libraries for Arria 10?
SyafieqS
Ashish,
You probably need to upgrade to 21.1 Standard version as that is the version started to support e Cadence Xcelium simulator replaces support for the Cadence Incisive Enterprise (ncsim) simulator.
