17255 Discussions
Simulation error for mod 3 asynchronous in Quartus II
I have used Quartus II 14.1 (64-bit version).
I made a mod 3 asynchronous counter as Fig 1.
The functional simulation issues the error message as Fig 2.
And, the timing simulation result is weird.
I expect the result sequence is 00->01>10->(temporally 11)->00->01->........
But, the result is weird as Fig3.
Is this a simulator bug? Or, let me know what is a part of mistake.
Th higher version of Quartus II 14 is as the same.
Ed
Iteration limits occur when you have a logic loop that cause the system to oscillate in 0 time. It's probably something to do with the loop cause by the resets
I understand why the error has occurred.
However as to the solution, I am unsure which parts must be altered or modified in order for the simulator to perform correctly like an actual circuit.
Actual circuit is working correctly.
It works good in version 13.
