State Machine Viewer
I designed a state machine in my verilog codes. I evaluate it in the DE2-115 board, and everything looks good. When I opened the state machine viewer in the Quartus II 12.0, however, it shows all the nodes but no transitions or transition conditions are shown. Can anyone help to explain why this is the case? Is there anything wrong?
-Roger
always @(posedge clock or negedge reset_n) begin
if (~reset_n) begin
cs <= stIdle;
end
else begin
case (cs)
stIdle : begin
DataWindow <= 1'b0;
ReadWindow <= 1'b0;
Done <= 1'b0;
index_write <= 0;
index_read <= 0;
if (start) begin
Done <= 1'b0;
cs <= stLoadData;
end
end
stLoadData : begin
DataWindow <= 1'b1;
cs <= stLoopWrite;
end
stLoopWrite : begin
index_write = index_write + 1;
if (index_write == read_length) begin
DataWindow = 1'b0;
cs = stReadData;
end
end
stReadData : begin
ReadWindow <= 1'b1;
cs <= stLoopRead;
end
stLoopRead : begin
index_read = index_read + 1;
if (index_read == read_length) begin
ReadWindow = 1'b0;
cs = stDone;
end
end
stDone : begin
Done <= 1'b1;
if (~start) begin
cs <= stIdle;
end
end
default : begin
cs <= stIdle;
end
endcase
end
end
Don't know about that, but why do you mix blocking (=) and non-blocking (<=) assignments in your code?
That is really bad coding practice and can lead to numerous subtle simulation vs implementation errors.
I would recommend you change all the blocking to non-blocking assignments.
It may also be why the tool can't detect the state transitions, but I'm just guessing on that.
