Static variable error
hey
I have a error when I write the static variable in kernel function.
Here is a simple example.
void funA()
static int b = 0;
void kernel fun(__global int *a)
funA();
Don't I use the "static" in opencl kernel ?
regards.,
My question is why the static variable is required?
The OpenCL language specification does not allow static variables. See Section 6.8.f "The extern, static, auto and register storage-class specifiers are notsupported."
--- Quote Start ---
hey
void funA()
static int b = 0;
funA();
regards.,
--- Quote End ---
You can however define constant data at file scope:
__constant int b = 0; void funA() { // Access b here } void kernel fun(__global int *a) { funA(); }
