17241 Discussions
Stratix IV GX - ALTPLL in VHDL
Hi!
Devide used: Stratix IV, EP4SGX180KF40C02N
Software used: Quartus II, 13.0.1.232; also tried compiling with v12 and v9.
I am trying to get a simple PLL frequency multiplier running in VHDL using the megafunction "altpll", which generates 320MHz out of 40MHz:
--------------------------------------------------------- Begin of Code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library altera_mf;
use altera_mf.altera_mf_components.all;
entity test_stratix_pll is
port (
clk0_in : in std_logic -- 40MHz
end;
architecture BEHAVIOR of test_stratix_pll is
signal clock : std_logic := '0'; -- 40MHz
signal highspeed_serial_tx_clock_320MHz : std_logic := '0';
signal highspeed_serial_tx_clock_320MHz_all : std_logic_vector (9 downto 0);
begin
Clock <= clk0_in;
highspeed_serial_tx_clock_320MHz_generator : altpll -- generates 320MHz from the 40MHz-Clock.
generic map (
intended_device_family => "Stratix IV",
clk0_multiply_by => 8,
clk0_divide_by => 1,
inclk0_input_frequency => 25000,
inclk1_input_frequency => 25000,
operation_mode => "normal",
width_clock => 10
port map (
--clk(0) => highspeed_serial_tx_clock_320MHz,
clk => highspeed_serial_tx_clock_320MHz_all,
inclk(0) => clock,
inclk(1) => clock
end BEHAVIOR;
----------------------------------------------------------- End of Code
With a Cyclone II using the following code for the altpll in the otherwise identical VHDL it worked immediately as intended, verified per oscilloscope:
generic map (
port map (
inclk(0) => clock
But with the Stratix i get the huge list of error messages shown at the attached file quartus-error-messages.txt ...
I also tried all the parameters the MegaWizard gave me, and most of these described in the altpll-documentation, and a lot of variations of it (i spent about 2 days with it....), with or without reset lines and so - no change... for example:
GENERIC MAP (
bandwidth_type => "AUTO", clk0_divide_by => 1, clk0_duty_cycle => 50, clk0_multiply_by => 8, clk0_phase_shift => "0", compensate_clock => "CLK0", inclk0_input_frequency => 25000,
intended_device_family => "Stratix IV", lpm_hint => "CBX_MODULE_PREFIX=bla", lpm_type => "altpll", operation_mode => "NORMAL", pll_type => "AUTO", port_activeclock => "PORT_UNUSED",
port_areset => "PORT_USED", port_clkbad0 => "PORT_UNUSED", port_clkbad1 => "PORT_UNUSED", port_clkloss => "PORT_UNUSED", port_clkswitch => "PORT_UNUSED", port_configupdate => "PORT_UNUSED",
port_fbin => "PORT_UNUSED", port_fbout => "PORT_UNUSED", port_inclk0 => "PORT_USED", port_inclk1 => "PORT_UNUSED", port_locked => "PORT_UNUSED", port_pfdena => "PORT_UNUSED",
port_phasecounterselect => "PORT_UNUSED", port_phasedone => "PORT_UNUSED", port_phasestep => "PORT_UNUSED", port_phaseupdown => "PORT_UNUSED", port_pllena => "PORT_UNUSED",
port_scanaclr => "PORT_UNUSED", port_scanclk => "PORT_UNUSED", port_scanclkena => "PORT_UNUSED", port_scandata => "PORT_UNUSED", port_scandataout => "PORT_UNUSED", port_scandone => "PORT_UNUSED",
port_scanread => "PORT_UNUSED", port_scanwrite => "PORT_UNUSED", port_clk0 => "PORT_USED", port_clk1 => "PORT_UNUSED", port_clk2 => "PORT_UNUSED", port_clk3 => "PORT_UNUSED", port_clk4 => "PORT_UNUSED",
port_clk5 => "PORT_UNUSED", port_clk6 => "PORT_UNUSED", port_clk7 => "PORT_UNUSED", port_clk8 => "PORT_UNUSED", port_clk9 => "PORT_UNUSED", port_clkena0 => "PORT_UNUSED", port_clkena1 => "PORT_UNUSED",
port_clkena2 => "PORT_UNUSED", port_clkena3 => "PORT_UNUSED", port_clkena4 => "PORT_UNUSED", port_clkena5 => "PORT_UNUSED", using_fbmimicbidir_port => "OFF", width_clock => 10
I would be very grateful for any hint what i can do to get the PLL running.
Thanks in advance, best regards :-)
You should use MegaWizard Plug-In manager and re-generate the PLL once again for your current architecture.
Hi, and thanks for the reply;
but i did just that again and again...
When i generate a new Quartus-project using EP4SGX180KF40C02N , using the above VHDL-code, and inserting the GENERIC MAP (..) generated by the MegaWizard inside this project into this code, i have exactly the described problem.
When i do exactly the same for a Cyclone-II which i am also using in another part of our project, it works instantly.
What shall i do?
Best regards :-)
It works when you create megafunction using the wizard.
COMPONENT mypll IS
PORT (
inclk0 : IN STD_LOGIC ;
c0 : OUT STD_LOGIC
END COMPONENT ;
mypll_inst : mypll
PORT MAP (
inclk0 => clk0_in ,
c0 => clock
Thanks a lot! Using the component and instances of it instead of directly copy-pasting the generic map() and port map() from the megawizard-vhdl as i did before (and which worked for the cyclone) made the PLL work also for the Stratix :-)
Best regards :-)
