Hello.
I used Quartus II MegaWizard to make a "tri-port-ram" using M9K unit, in the width of 18X512. (One Write Input, Two Read Inputs, Two Output Ports). How can I verify that the module is based on a single m9k unit and not on two M9Ks?Link Copied
The easiest/fastest way without thinking too much about it is to simply create a blank project and set your MegaWizard file as the top level entity and compile it.
Review the Fitter reports to see how many M9K it used.- Mark as New
--- Quote Start --- The easiest/fastest way without thinking too much about it is to simply create a blank project and set your MegaWizard file as the top level entity and compile it. Review the Fitter reports to see how many M9K it used. --- Quote End --- Thanks. Indeed, It can be seen that the Quartus uses two units of M9K to provide a "three-port" RAM unit with two Read-Inputs. Thank you very much. Lior.
