I have tried structural modeling examples from Bhasker in Quartus . I cannot rectify the following error.
entity HALF_ADDER is port(A,B: in BIT ; SUM ,CARRY:out BIT); end HALF_ADDER; architecture HA_STRUCTURE of HALF_ADDER is component XOR2 port (X,Y:in BIT; Z:out BIT); end component ; component AND2 port (X,Y:in BIT; Z:out BIT); end component; begin X1:XOR2 port map(A,B,SUM); A1:AND2 port map(A,B,CARRY); end HA_STRUCTURE; ERROR Error: Port "X" does not exist in primitive "AND2" of instance "A1" Error: Port "Y" does not exist in primitive "AND2" of instance "A1" Error: Port "Z" does not exist in primitive "AND2" of instance "A1" Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 4 errors, 0 warnings Error: Peak virtual memory: 216 megabytes Error: Processing ended: Mon Dec 20 06:08:46 2010 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 6 errors, 0 warnings Kindly also mention the right documentation to referLink Copied
How did get the names and2, or2. These are reserved names and lead to errors.
