Using Synplify Pro as a synthesis tool we pass it a project file that has all of the
options and input files. One such option is the following which is wrong. set_option -technology CYCLONE V set_option -part 5CGX etc Does anyone know where the correct numbers are for the -part Cyclone series chips are? For example, I had a Cyclone II and it took me 30 minutes or so to finally get the number correct. I was using the full part number and Synplify did not like that. Below is what it likes. The correct format for this is: set_option -technology CYCLONEII set_option -part EP2C70 There must be a list somewhere. A search on the internet did not provide me with any answers. Also, is there a space after the word CYCLONE before one puts a II or V ? There was no space above and it worked. There must some document describing the correct syntax. I have not found it. Thanks, PWSLink Copied
