Hi all Im a new user,
I am trying to compile an FIR but I don't want to use the embedded multipliers/memory in my design. Insted I want to map my entire design into Logic Blocks. Is there any option to tell Quartus not to use embedded multipliers/Memory. GanenLink Copied
Uncheck auto ram replacements select logic element for dsp block balancing in QT settings
Thank You MarkMan.
Just to make it more obvious for future ref Assignments-->Settings-->Analysis &Synthesis Settings Thanks once again Markman
