17254 Discussions
System console closes channel
I have a system console running to control my system via a Jtag -> Avalon MM Master, and it runs fine. But occasionally after I have configured my parameters and I try and read back some status it says "Channel closed".
In full:
error: master_read_32: com.altera.systemconsole.core.services.ChannelClosedException: Channel closed while executing
"master_read_32 $jtag_master2 0x800 16"
Any clues? Is this normal? Is something else interfering? Would an OpenCore Plus license being managed using the same USB-Blaster->Jtag connection interfere?
Struggling to find a reason.
The core that was configured still runs though, so it's not reset things or similar.
same here. any thoughts?
PareshKJoshi
Try by reducing the jtag speed..
Reducing the jtag speed worked for us.
For example : With only 1 single USB blasterII plugged this will be, to make jtag Frequency 6MHz.
>jtagconfig --setparam 1 JtagClock 6M
Paresh K. Joshi
