17245 Discussions
SystemVerilog supported by Quartus?
I have files written in SystemVerilog but they are saved with the extension .v
Does the Quartus support SystemVerilog design files?
What do I need to do for the SystemVerilog files but saved in .v extension?
I would have thought all you would need to do is change the file
extension to .sv
jt
Quartus projects treat .v & .sv files the same way: according to Settings -> Analysis & Synthesis Settings -> Verilog HDL Input -> Verilog version. By default it's Verilog-2001. Set to SystemVerilog-2005 to enable use of sv keywords and features.
If you set the global option to "SystemVerilog" then all files (*.v or .sv) will be synthesized with SV extensions. If you use .sv in your extension, then Quartus will us SV for those files. In the .qsf there is a different keyword for SV.
set_global_assignment -name SYSTEMVERILOG_FILE ../src/I2C_Master_PSOC/I2C_Master_PSOC_IF.sv
set_global_assignment -name VERILOG_FILE ../src/VCCIO_Controller/LTC2620.v
Ed
Alternatively you can place this commented out line at the top of your SystemVerilog file (if you don't want to declare your whole project to be SystemVerilog):
// synthesis VERILOG_INPUT_VERSION SYSTEMVERILOG_2005
