17254 Discussions
Systemverilog packed structs in Quartus II?
Re-posting here from the general forum where I posted by accident . . .
I have a systemverilog header file (types.svh) that contains a number of the following:
typedef struct packed {
bit [127:0] field1;
bit [63:0] field2;
bit [127:0] field3;
bit [63:0] field4;
} name_of_struct;
When I try to synthsize it in a file:
`include "types.svh"
module mod_name(i_port, ...)
input name_of_struct i_port;
Quartus II just dumps out a bunch of errors saying "Verilog HDL error: object "name_of_struct" is not declared. It's like QuartusII isn't actually seeing my `include file or something. Any suggestions?
If I include the struct declaration prior to the 'input . . . ' line in my code, it works fine, so there is something about declaring a struct in an external file that is broken. I can't believe Quartus wouldn't support such a basic feature though.
It works provided that you comply to this restriction:
The path to the include file has to be explicitely writen in your system verilog file. For example: `include "../include/types.svh".
