17257 Discussions
TCL Window to read compile parameters
Is there a way to launch a window to read a few parameters when we hit the compile button in Quartus GUI? I have a pre_flow tcl script that is executed to create a revision for the compile. Now I need to provide some additional parameters to the build. I am hoping I can reuse the same pre_flow script to provide this feature. I am envisioning providing a pop-up where the engineer inputs the value hits return and then the compilation process continues. It doesn't have to be a pop-up as long as there is way for users to enter the data.
Want to prevent any excuses to forgetting to rev up the revision before a compile.
Thank you.
Sanjay
Did you want a pop-up, or do you just want a procedure that someone needs to follow?
A while back I posted some Tcl/Tk GUI tests that would work in the Quartus GUI ...
http://www.alteraforum.com/forum/showthread.php?t=27920
But you can also just add a parameter to the design via Assignments->Settings, Analysis & Synthesis Settings, Default Parameters, and then edit that. The pre-flow script can read that parameter as part of the synthesis flow.
The DSP examples in this tutorial
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104code_hawkins.zip
use that method, i.e., you change the EXAMPLE parameter, and the pre-flow script changes the design.
Cheers,
Dave
Thanks. Yes! I do want a pop-up. Without a pop-up, I can increment the rev with a text file just before the compile. But technically, a hard brake in the processing before incrementing the revision avoids situations where one can forget to roll up the rev during the frenzy of debug. This is extremely valuable in a team where compiles occur often during a day.
Thank you.
Sanjay
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Then try the Tcl/Tk examples I linked to. They worked fine the last time I tried them. If for some reason they do not work from the Quartus 14.0 GUI, let me know, and I'll take a look at them.
Cheers,
Dave
Dave,
This is brilliant. Thank you! entrybox_ex.tcl is a great example.
Happy Friday!
Sanjay
Hi Sanjay,
--- Quote Start ---
--- Quote End ---
Great! I'm glad to hear the examples helped.
Cheers,
Dave
