17255 Discussions
TCL parameters and Include directories
Hi All,
Is there any documentation on the TCL parameters for all the functions provided by quartus?
For example,
set_global_assignment -name ???
What are all valid assignments and their meanings for the -name flag? There are a lot of other functions which I cannot find their full parameter options description.
Also, is there anyway to specify and "include" dir; something like +incdir+ in modelsim (or -I flag in gcc). This might be useful if I have .vh files found in some common location.
thanks!
there is a Scripting Reference Manual:
http://www.altera.com/literature/manual/tclscriptrefmnl.pdf
i create .qip files for various libraries. then i can add the library by editing the .qsf and adding the .qip file. for example:
set_global_assignment -name QIP_FILE ../vhdl_2008_fixed_float/vhdl_2008_fixed_float.qip
would mean at the same level as my project directory i have a directory containing the VHDL 2008 fixed/float packages
I think you may be looking for the Quartus II Settings Manual located here:
http://www.altera.com/literature/manual/mnl_qsf_reference.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=qsf%20settings
Thanks for the feedback, I found what I was looking for in one of the Altera manuals:
If the Quartus II Settings File contains a USER_LIBRARIES assignment and you call set_global_assignment to set a SEARCH_PATH or USER_LIBRARIES assignment, the existing USER_LIBRARIES assignment expands into one or more SEARCH_PATH assignments.
So, if you have a set of .vh files in some <DIR> to can:
set_global_assignment -name SEARCH_PATH <DIR>
this seems to work!
thanks!
